It's the MJPeg codec. Compression that uses direct cosine transforms, as does MJPeg, MPEG and many others, by their nature are lossy. The lower the data rate or higher the compression ratio the more lossiness. YUY2 or HuffYUV give full quality with little or no loss.
The cost is resources. You need a fast drive subsystem and at least a 500-600 mhz processor. How fast a drive depends on what the maximum resolution is you want to use.
With a single Maxtor DiamondMax Plus 40 (7,200 rpm, ATA66) you can capture up to 352x480 easily. For 704x480 captures you would need a 2-3 drive RAID0 array using a Promise Fasttrak66 or Fasttrak100 as this resolution requires 22 megs/second for straight YUY2.
Yes guys, the Fasttrak100 will be in stores soon. I have a preview board running right now. With two IBM 7,200 rpm ATA100's it posts just over 68 megs/s sequential writes in SANDRA Pro 2000.
In order to do these alternate codec captures you also need to use a capture utility other than PC-VCR as it can't use external codecs. AVI_IO is my primary choice because it can keep the audio in synch over VERY long serial captures. VirtualDUB is choice #2.
[This message has been edited by Dr Mordrid (edited 14 June 2000).]
