Gurm I never said serial ATA would do more than 1 drive, which is good since we should end up seeing 4 serial ATA ports on MOBO's as standard eventually(so I will never be in the situation where I am forced to share a channel)
I have 3 HDD's on separate channels, and my DVD and CD/RW sharing the other channel.
So I want to add another HDD, how can I add another HDD and still maintain the current performance levels.(without getting another controller)
It can't be done because the perfomance limitations of the 2 drives on an a single channel.
I do know that there is no drive currently available IDE hdd that will come close to maxing out ATA100 let alone ATA133(except maybe some exotic solid state drives)
Edit: to add, 64bit PCI and 66Mhz PCI are not too uncommon anymore 100MBps is close the limt for "old" PCI tech, you can at least double that for people with dual athlon boards...etc
