Paddy:
Thanks! Guess I'll just have to seen how good it will be at keeping my (future) system cool.
There seems to be a pocket of hot air at the bottom/back of the case and at the very top. I quite often see internal temps exceeding 40’c! Although some of this is due to the mass of SCSI cables.
Looking at the structure of the case, I would recommend having an exhaust fan at the top of the case. Unfortunately, as the both side panels can be removed, the top is part of the structural integrity… and it’s an expensive case to mess us!
Aren't the two top-back exhaust fans sufficiant ? (I would think that if there is hot air at the top back, these fans would be perfectly located). I certainly don't intend to "hack" the case (knowing my DIY-skills
The stock fans at the font do a great job at cooling my hot drives, but they just move the hot air back into the depths of the case. The exhaust fans are placed halfway up the case and so there is always warm air above them.
As you say, the sucked in air from the front first passes the harddrives, so it isn't "cool" anymore when it reaches the mainboard. But above the back fans, there is the PSU (mounted on a plate). So is there still room for warm air above them ?
I have minimised obstruction where possible, except for a few cables. The problem i have is there is no airflow between the PCI cards. Those Adaptec SCSI cards generate a lot of heat.
Yes, I currently have only one 2940UW, but I will need to purchase a 39160 in order to fully benefit of the speed of my drives (esp. when I intend to add one more). Aren't the 40mm fans located near the PCI-cards usable for cooling PCI-cards ? Perhaps with a fanduct ?
Most of my other PCI-cards aren't that hot though. As my system has fewer drives than yours, cable obstruction currently doesn't really seem a problem for me (I still manage to tuck away the cables nicely
