After much reading I have come to the conclusion that you can do it either way.
If you do it all in series, then the water reaching CPU1 will be warmer than CPU0 and therefore CPU1will have a higher resulting temperature. This doesn't matter if the water is flowing fast enough. SCompRacer has adopted this method, and it looks as if he has done it well as the second CPU is only .4'C warmer.
If you opt for the parallel option (with the split) you have to ensure that the resistance down both pathways is identical or you will get a disproportionate flow down one of them.
To be honest, I dont think it really matters. Doing it in serial is much more straight forward, with less connections and therefore less chance of leakage.
I will be going for:
res > pump > cpu0 > cpu1 > rad
You're right about the resistance in both pathways (in the parallel options), this is why I added the option with the extra pump. But serial will probabely be the way to go
