Just to add a little to the topic: GT, a rule of thumb for radiators is to look at its size - bigger most of the time means more surface area, which means more heat dissipation (of course, if it's huge and has no fins, there won't be that much surface area). Bigger fans are better, too, because they can move more air and/or be quieter (and are almost guaranteed to have a more pleasing sound than smaller ones).
So a Radiator for a 80mm blowhole likely won't perform all that great.
