At wich temps??
MSI 745 o/c help
Seeing as the temps are now dropping in Minnesota, I can keep it under 50C with ease with the windows open...Originally posted by Technoid
At wich temps??
Peaks at 54C with my Delta running at 1/3 power running at 1.9ghz@2v
No voltmod, BTW. I can go all the way upto 2.2v in the bios with the 8K3A+....one of the main reasons I'm looking forward to the Epox 8RDA+....Let us return to the moon, to stay!!!
at what ambient room temp?
(if ya gonna tell the story, tell the whole story
ok just for fun i slaped a 6800rpm PAPST on the zalman, was stable up to 1750Mhz (@1.85V). that beast is louder than a jet engine though
i dont think that baby can do more than this, even not with water cooling. not enough juice.
anyway 1680Mhz didnt proove to be perfectly stable, UT2K3 jumped to the desktop with general protection fault once (and this baby got hot up to 75C
) so i lowered to 11.5x142 = 1633 which is perfectly stable and also quite "cool" (65C max).
I'm sure it will Thop, just need to make the Vmod (did it to mine) and have better cooling"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." -- Dr. Seuss
What reading do you see when in the BIOS (&which BIOS) VS. when using a quality DMM?
When in the BIOS you see a better measurement of said voltage, but still not as good as I can read with my Fluke 867BE GMM... ie software monitoring just sucks."Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." -- Dr. Seuss
