Well...
Im NOT using linux as my primary OS.
Its winxp (no servicepack). The couple of times I have had problems with my windoze, I have been able to correct them from the recovery console (its the black n white doslike thingy - acces via the original install cd). It havent been easy every time, but last time was a breeze. And heres why.
I have a version of Knoppix. Boots of the CD. doesnt touch ANYTHING on the system, unless you really go out of your way to allow it.
I booted from this cd, it made a complete install, nic, usb keyboard n mouse, sound, grafix, screen, printer. I went to the winxp forum, browsed for a solution, printed it, and restarted into the winxp recovery console. Problem solved.
Having just installed a couple of versions of winxp (with slipped sp1a), Im quite envoius about the installation that knoppix makes. No hassle, no reboots (Dooh!), 2 minutes tops - complete installation, including seveal browsers, openoffice, cd burners mp3 and divx players - you name it.
Admittedly, I could have gathered all the "common" winxp programs on one dvd +r and shortened the install time. But still, it takes me several hours to complete any winxp install - with reboots into the high teens. MS office, Adobe series, winzip, Nero, updates and configurations, driver downloads etc.
This isnt exactely Microsofts fault - well the many, many reboots when installing and updating winxp and MS office IS MS's fault - but 3'party software is in fact something you buy on the Windows OS' - so kind of hard to make a unified install. I Know. But. Still. I. Hate. Reboots.
~~DukeP~~
~~DukeP~~
