The hard drives are still rather expensive, 160G for about 85 Euros.
Best data storage solution for scanned films?
Hmm, I guess the Lacie Bigger disk solution is also too expensive...
Up to 1.6 TB of harddiskstorage, with Firewire of USB/firewire:
Just a weird thought : do you need to keep those scanned images? In other words: is it possible to scan again when the original is needed? Or is there too much chance these originals will also degrade?
I wouldn't call that expensive, especially considering how much time you'd have to spend when burning CDs and DVDs (burn, verify, change disks etc.)
doing some quick math here:
80MB per frame results in
about 2000 pictures per 160GB HD
costs total around 100,- €
so on average 5 cents per picture
or about 50 pictures per DVD
so for 2000 pictures, you'd need 40 DVD medias and a burner
reliable DVD medias (scratchproof) are still a bit pricey, so let's presume you'd pay 1,- € per disk, plus ~80,- € for a decent burner, totalling at 120,- €
so on average 6 cents per picture
so what's more expensive now ?
don't forget the time factor having to play DVD jockey versus swapping a HD every 2000 framesDespite my nickname causing confusion, I am not female ...
Intel Core i7-3930K@4.3GHz
be quiet! Dark Rock Pro 2
2x MSI N670GTX PE OC (SLI)
OCZ Vertex 4 256GB
Nanoxia Deep Silence 1
LG BH10LS38
LG DM2752D 27" 3D
Sure, you're right Maggi. And HDs are much faster. But I still feel a bit uneasy with changers frames: I worry about something could happen, like dropping the discs on the ground unintentionaly. One of my brother's hard discs was defect, probably only because the electricity in Peking was not stable enough. All data was lost.Last edited by chaoliang; 25 October 2004, 06:50.
Well they have a casing around them but they still don't like being droppedOriginally posted by chaoliang
Are external hard discs better protected against accidents than internal ones?
Any ideas of a budget for this solution?When you own your own business you only have to work half a day. You can do anything you want with the other twelve hours.
dunno how Al pulled those 4TB, but my calc tells me you'd need about 350-500GB storage, which could be covered by two of these:
OCZ Vertex 4 256GB
LG BH10LS38
LG DM2752D 27" 3D
This is worth a look
A commercial and industrial construction firm committed to providing personal superior service regardless of the type and location of the project. Our mission is to exceed our clients’ expectations by providing construction services that are unparalleled in the industry with regard to safety, integrity, quality, and schedule. We bring unprecedented experience and expertise to every project, giving clients confidence and peace of mind.______________________________
The best solution is the most "solid".
An HD or a tape can always be accidentally erased, or be faulty and you will not discover it until you will need your data.
Put all the image on DVDs, then insert them into some good DVD holders, the ones who have both sides filled with "soft material" and each folder made in "no-scratching" material.
Then use few few money for a tool that can do "void" into a plastic bag. Insert each one of the dvd holder into a plastic bag, then use the void machine on the bag.
Put everything into a drawer, and simply remember to re-burn the DVD in 2015.Sat on a pile of deads, I enjoy my oysters.
