Originally posted by Drizzt
The best solution is the most "solid".
An HD or a tape can always be accidentally erased, or be faulty and you will not discover it until you will need your data.
Put all the image on DVDs, then insert them into some good DVD holders, the ones who have both sides filled with "soft material" and each folder made in "no-scratching" material.
Then use few few money for a tool that can do "void" into a plastic bag. Insert each one of the dvd holder into a plastic bag, then use the void machine on the bag.
Put everything into a drawer, and simply remember to re-burn the DVD in 2015.
First, it's very hard to accidentally erase a tape. Second, DVD-Rs cannot be expected to last 10 years. 5 if you're lucky.
Just put them in a fireproof safe...
