I have a jumper for tweaking the I/O voltage on my i815EP board. Even thought I was a little tipsy, I actually had the presence of mind to check.
Whether or not it works is another story.
One bad thing about the motherboard is it appears you *have* to get to get to 133 MHz for the 1/4 PCI divider to kick in. With the VIA Apollo Pro 133A, and even BX boards, you could run the FSB at 124 MHz and clock the PCI bus down to 31 MHz. I suspect Paul (Pace) might be facing the same thing with his Abit board, because it may be a limitation of the chipsets. It's the same thing with the AGP divider. The higher dividers seem to automatically kick in at 133 MHz, and there's no flexibility at lower clocks.
paulcs@flashcom.net
[This message has been edited by paulcs (edited 01 January 2001).]
Whether or not it works is another story.One bad thing about the motherboard is it appears you *have* to get to get to 133 MHz for the 1/4 PCI divider to kick in. With the VIA Apollo Pro 133A, and even BX boards, you could run the FSB at 124 MHz and clock the PCI bus down to 31 MHz. I suspect Paul (Pace) might be facing the same thing with his Abit board, because it may be a limitation of the chipsets. It's the same thing with the AGP divider. The higher dividers seem to automatically kick in at 133 MHz, and there's no flexibility at lower clocks.
paulcs@flashcom.net
- but, I did read that it'll fit ok on my board - am I right?
