3D-games with G400. Problem
    Wombat, I must admit ACPI was my next suspect after the USB.... does ACPI actually work to the good of any system? I have had nothing but trouble with it on all my systems.....
    I agree with you, some Win2K users would be quite helpful right about now.
      HollyBerri
      1. This is new PC.
      2. I have this PC two monts and same time i have this problem
      3. This locks up at complete random
      4. Sometime screen looks fine but doesn't move, sometime screen partially or totally garbled
      5. Sound YES continue to play.
      6.mouse no respond
      7. no
      8. PC work fine w/o other errors...
      My IRQ list :
      9 - Creative SB LIVE! (VAlue)
      9 USB Host Controller - 2442
      9 USB Host Controller - 2444
      9 Matrox G400
      9 US Robotics Modem
      9 ACPI
        First of all, you need to install the i815e inf from Intel. Then you need to uninstall your Matrox drivers using add/remove programs/Matrox Software. Then reboot, when windows picks up your Matrox card, hit cancel, then run the setup for the 5.52 drivers, you should be good to go.
        Rags
          Free beer on irq 9!!!
          System 1:
          AMD 1.4 AYJHA-Y factory unlocked @ 1656 with Thermalright SK6 and 7k Delta fan
          Epox 8K7A
          2x256mb Micron pc-2100 DDR
          an AGP port all warmed up and ready to be stuffed full of Parhelia II+
          SBLIVE 5.1
          Maxtor 40g 7,200 @ ATA-100
          IBM 40GB 7,200 @ ATA-100
          Pinnacle DV Plus firewire
          3Com Hardware Modem
          Teac 20/10/40 burner
          Antec 350w power supply in a Colorcase 303usb Stainless
          New system: Under development
            HollyBerri
            No, this system builded be myself.
            Disabling USB not help...
            Rags
            Explain please, what do you mean "i815e inf from Intel" ?
              Yason, go here http://developer.intel.com/design/software/drivers/platform/3961/inf_utility/lic_i nfinst.htm
              Then on then bottom of the page click on "Yes i agree ...", then on some server (the US web server preferably).
              When you have d/l it, unzip, run setup.exe et voila.
              Download the <A HREF="ftp://ftp.matrox.com/pub/mga/archive/win_2k/2001/w2k_552.exe" TARGET=_blank>
              5.52 drivers</A> double click on the w2k_552.exe, unzip them somewhere eg. C:\Matrox\552\
              Then download the <A HREF="ftp://ftp.matrox.com/pub/mga/utils/pd_unin201.exe" TARGET=_blank>
              PDUninstaller</A>
              Run the uninstaller, when prompted, reboot. Windows will ask you for drivers once rebooted, click Cancel. Run the Setup.exe from the 5.52 drivers and then reboot again. Ok?
              Sorry if i`ve kept it too simple guys, but i think it`ll be easier for him ...
              I`m peachy, Kate. The world is my oyster.
              [This message has been edited by omegaRED (edited 26 May 2001).]
              Seth, are you ok? I`m peachy Kate. The world is my oyster. - Seth Gecko
                NO!
                DON'T run the uninstaller! USE ADD/REMOVE PROGRAMS!
                Rags
                  Rags ... ?!?
                  Seth, are you ok ?
                    The uninstaller is for earlier versions of powerdesk. The addd/remove programs does a complete job with the later powerdesk.
                    [size=1]D3/\/7YCR4CK3R
                    Home: M1 Mac Mini 8GB 256GB
                    Frontdesk: Beelink T4 8GB
                      Although that might not be entirely true. I checked the new uninstaller, and it's dated as May 16th 2001 on the Matrox site. It also states it's for every Windows including 2000.
                      <font face="Verdana, Arial" size="2">This utility is used to uninstall all Matrox software, including display drivers, Powerdesk software and video capture/editing software ("Matrox Video Tools") in Windows 95, 98, ME, NT and 2000.</font>
                      Jord.
                      Jordâ„¢
                        Yeah, listen to Jorden, it's not like I haven't tried this myself
                        If you haven't bunked an install of drivers yet, just use Add/Remove. If you have messed up the install by using an .inf instead of the setup under 2k, use the uninstaller to get you started again.
                        Rags
                          lol...
                          I haven't tried the new uninstaller Matt, I just checked the date and all, since I never heard of a PD_Unin201.exe
                          My bad, okay?
                          Jord.
                          Jordâ„¢
                            No problem it's just best to get in the habit of using add/remove programs to do your driver uninstalls, all drivers will eventually get to this point, and Matrox has had theirs functioning quite well for some time.
                            Rags
                              Big thanks boys, but...it's not work - same problem
                                Im back.
                                Not to say "I told U so", but somehow I just NEW that a Soundblaster Live (value even!) would be involved.
                                Im really happy that All You people are trying to help us out here. I have checked all the suggestions so far, and I have tryed them all, to no avail. Yes, all my units are on IRQ 9 too, thats just the way the cookie crumbles, at least under win2k. I have all of Intels patches (even the new udma4 ones) and all the newest drivers and bios. I REALLY dont think theres anything to do.
                                Yason, U sure U have the same problems under Direct X? I Only get these freezes in opengl.
                                Thx Rags, Jorden, OmegaRED, DentyC, HollyBerri, Wombat, Alec and al.
                                ~~DukeP~~
