Alpha PAL 8045!
    Luckily the Gulf stream make's it rather hard to find glaciers....
    It's been warm here this winter... today it was 80f/26.6c
      If it wern't for the gulfstream the climate in sweden would be like northen alaska....
        The PAL8045T looks good, I think I will get one too as soon as I get the money for an Athlon XP mobo+processor. I'll take one with a nice medium-speed fan, because the two Y.S. Tech fans on my Globalwin VOS32 are starting to get on my nerves... Just checked the Y.S. Tech homepage and the fans are rated at 35 dB(A) each >><<
          quiet HSFs and cases
          All you noise wimps are a bunch of weenies!!! Try working on a machine floor for a while and you'll learn to appreciate the little bit these PCs put out. Ah, the good 'ol days in the glass house. The floor manager would walk around with ear muffs. I guess the operators had to do without to keep an ear open for crashing disks. I could see minimizing the noise if you're building a HTPC system but why the strife over a workstation? I opted to make sure my system was cool and long lasting. My case has two 120mm fans (intake and outflow) along with the PS fan. The CPUs have both been retail Pentium !!!s with stock HSFs. I don't OC though.
            Before my Genuine Abit Quality&trade; mainboard died I had:
            -Main system with VOS32 with the 2 above mentioned loud 6 cm fans, 2x12 and 1x8 cm case fans, power supply fan, blue orb and 2x7200 RPM hard drives in RAID 0
            -Another system with dual Athlon fans, 2x12 and 1x8 cm + power supply fans and one helluva noisy old Maxtor hard drive
            I slept <1,5 meters from these systems while they were crunching DivX, Genome or whatever...
            Oddly, I seem to sleep better now with just one system running
              I forgot some of you folks sleep with your computers. My office is several rooms down the hall from the bedroom. If I wanted to quiet the home more I'd first look at doing something about the fridge.
                For some here its the closest to a female they get!
                RedRed
                Dont just swallow the blue pill.
                  Good thing I'm studying at an University, eh!!!
                    During his younger years, Guru's mother throught he just couldn't contain his enthusasm...
                    Now we know it's just a bad case of Glossus Erectus
                      My fridge in my apartment is twice as noisy than my two computers running with all fans!!
                      Some of the erlier tenants has already tried to put it out of its missery....
                      One of the sides are realy beat up....
                      I'm seriously thinking of having it replaced......
                      One way or another.......
                        Just get a normal cpu that doesnt overheat with a small retail heatsink
                          LOL
                            HEHEHEHEH!!!!! Too true Red!!
                              Like what?
                              A intel cpu mayby???
                              The P4's can be opperated without a HS!!
                              So I don't consider them "Normal"
