Pentium 4: More speed in the pipeline
    Originally posted by Guru
    Heard that the P4 800fsb will cost ~ 20€ more then the same 400/533 models!
    that's encouragin :-)
    The P4 lives and shines with LOTS of MHz
      IIRC amd said the first A64 will be 800MHz at US$1099, not sure if thats retail price or price of 1000.
      I think, like Itanium, it is just not meant to be for consumers...
      In terms of Pi calculation or something like that, I doubt the 800MHz A64 would be faster than the (then) fastest Xeon...
        Wy, I think you got something wrong.
        If you talk about bus speeds, AMD doesn't use a conventional bus with the A64. If you talk about core frequency, then 800MHz are the speed of which the Sledgehammer (opteron) samples ran at last spring. I say you should expect far higher frequencies than that at launch. And that's the Opteron, the Athlon 64 should run a fair bit faster!
          Yes you are right and I was confused, sorry.
            Damn i wondered when P4's architecuture will reach its clock limit...
              Don't worry, when it does, Intel will double the pipeline length again, up the clock by 80%, and call it the Pentium5
                No doubt!
                  There is a yer old article on anandtech where they show an air cooled p4 @ 10GHz!
