You could always go for an IED 3200
Hi-fi woes
I haven't really got my speakers in the best place, might try move em down a foot or so.Attached Files______________________________
I'll give moving them a go, it will probably sort things out. Thanks for the advice. That IED 3200, probably costs the same as a car! from reading the specs i take it that's what they might use in a airport to phase the speakers so you can actually hear the announcements.______________________________
I don't remember the make of my friend's amplifier, but it has a microphone that came with it. It has you place the microphone at a few different listening positions, and tunes its output accordingly.Originally posted by gt40
When I set up my system, I had two friends help.
one had a speaker each, and I had them move them to my directions while I sat in the 'listening position'.
once the sweet spot was found, it was jus a matter of convincing my beloved that the speakers 'had' to be there.
sometimes this procedure can save you alot of money/aggevation, and usually there is no money that can compensate for badly placed speakers.Gigabyte P35-DS3L with a Q6600, 2GB Kingston HyperX (after *3* bad pairs of Crucial Ballistix 1066), Galaxy 8800GT 512MB, SB X-Fi, some drives, and a Dell 2005fpw. Running WinXP.
Also adding some acoustic foam panels behind the speakers to reduce slap echo would make a significant improvement
+ put some space between the speaker and the rear wall
Kv is correct, tweeters about ear level is best"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." -- Dr. Seuss
I better start eating more eggs
I have put the foam plugs in the port tube at the back. Which made the bass less boomy.
It just irritates me that i spent x amount of money on hifi sure i can hear more detail etc, but the same music is more fun to listen to in the car listening to the radio!
Wombat i think your friend might have this ...TACTaudio http://www.tactaudio.co.uk/
That does room correction, and they also do high quality Class-D amps (fully digital / and not theoretically an amp). They look pretty nice too.
egg crates hardly do anything more than breakup reflected sound... you need something that absorbs"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." -- Dr. Seuss
Last edited by Greebe; 7 July 2004, 17:21."Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." -- Dr. Seuss
Controlling first reflections is the number one goal in acoustically treating your room (and some notable speaker manufacturers make it a big part of their speaker designs.. see B&W's 800, 801, and 802.) Sounds emanate from the driver in a spherical shape. Only a small percentage of the waveform reaches your ears before bouncing off something. Most rooms sound best when there is an absorptive acoustical treatment on the floor and on the front wall, and a few areas on the side walls in the front half of the room (where the vector from the speaker to your ear bounces off the side wall at a 90 degree angle is the best place for a nice curtain or something.) As Greebe said, diffractive treatments are not usually worthwhile in this case. Do not deaden the whole room with foam or carpet, though.. reflective surfaces at the back or on the ceiling are not bad to have, and a too-dead room will not be pleasing at all. The sounds which bounce off the rear wall will reach your ear after the primary waveform, so will be perceived as ambience (usually a good thing if the room is large enough), but the primary goal is to be sure that the first message that reaches your ears is the one straight from the speaker.
Rooms can be designed for sound without looking like it. In my experience, placing the speakers on a wall where the ceiling slopes upward usually produces a very pleasing acoustic, and large open areas on either side of the speakers are also good.Last edited by KvHagedorn; 7 July 2004, 18:11.
Do you think moving them a little further away from side walls might help?
I read somewhere 3 feet is reccommended between speaker and side walls. I reckon i might be able to______________________________
