If that's what if took to solve your problem, good idea. Sounds like it is something you had better make sure you do periodically.
You probably should go one step further and remove the heatsink, clean it and the cpu core, and then reassemble them with a minimum of heat-transfer compound. It sounds like you are on the ragged edge as far as heat dissipation goes.
[This message has been edited by Brian R. (edited 24 July 2000).]
Team Anandtech
