Double check your vga cable and if possible,try it with another one,i'm using one that has 2 RF chokes on it(it came with my monitor),most cables only have one.
GeForce3 and 2D quality...
Hey Rags, see if u can pick up another brand of GF3 if u can. I'm considering a card with VIVO, so the Asus's GF3 card is being considered.Primary system specs:
Asus A7V266-E | AthlonXP 1700+ | Alpha Pal8045T | Radeon 8500 | 256mb Crucial DDR | Maxtor D740X 40gb | Ricoh 8/8/32 | Toshiba 16X DVD | 3Com 905C TX NIC | Hercules Fortissimo II | Antec SX635 | Win2k Pro
But did you try it with different vga cables on each monitor or did you use the same cable on all of them???
Just to make sure...note to self...
Assumption is the mother of all f***ups...
Primary system :
P4 2.8 ghz,1 gig DDR pc 2700(kingston),Radeon 9700(stock clock),audigy platinum and scsi all the way...
Superfly: Guess he uses it with ALL his 6 monitors on ALL of which his Matrox card looks much better.
Each one has it's own cable, all but one has double ferous filters.<font face="Verdana, Arial, Helvetica" size="2">Originally posted by superfly:
Just to make sure...</font>
Rags
Went to a lan party at my brother-in-laws house last night, what a blast!
There were 13 people, 7 of which had some form of nvidea ranging from tnt2 ultra to 1)gf3, 2 had radeons (1-64mb and one 32mb), 3 had 3dfx cards, and lowly me with my Suped up G400
ALL players asked what I was running after saying how clean it looked, and yes many were faster than mine, but I was playing all games with ease and winning a few even with my hyper extended left middle finger (karate accident
And I don't wear glasses at all
System 1:
AMD 1.4 AYJHA-Y factory unlocked @ 1656 with Thermalright SK6 and 7k Delta fan
Epox 8K7A
2x256mb Micron pc-2100 DDR
an AGP port all warmed up and ready to be stuffed full of Parhelia II+
SBLIVE 5.1
Maxtor 40g 7,200 @ ATA-100
IBM 40GB 7,200 @ ATA-100
Pinnacle DV Plus firewire
3Com Hardware Modem
Teac 20/10/40 burner
Antec 350w power supply in a Colorcase 303usb Stainless
New system: Under development
Maybe you could show them how to clean their moniter screens properly.
AMD Phenom 9650, 8GB, 4x1TB, 2x22 DVD-RW, 2x9600GT, 23.6' ASUS, Vista Ultimate
AMD X2 7750, 4GB, 1x1TB 2x500, 1x22 DVD-RW, 1x8500GT, 22" Acer, OS X 10.5.8
Acer 6930G, T6400, 4GB, 500GB, 16", Vista Premium
Lenovo Ideapad S10e, 2GB, 500GB, 10", OS X 10.5.8
O.K..so you eliminated the monitor and cables as a possible cause and you've tried 2 cards so it isn't a faulty card the problem either.
Exactly what do you see that doesn't look right compared to the G400???
Btw... do you have the possibility of trying the card on another system,just to see what happends,since the card is quite a bit more power hungry than the G400(it runs right at the limit of the agp spec).
Durango...
Just because other users have faster cards doesn't make them beter players...
Wanna go a little one on one with me,just for kicks...
note to self...
Primary system :
Problem number one: Shadowing of text at 1280/85hz and above.<font face="Verdana, Arial, Helvetica" size="2">Exactly what do you see that doesn't look right compared to the G400???</font>
Problem number two: Excessive screen shake.
Problem number three: mouse movements and scrolling cause flickering and/or flashing of pixels (quite annoying at times)
Uh, yah, that's the first thing I have done. All of my monitors are fine, and their cables are fine.<font face="Verdana, Arial, Helvetica" size="2">O.K..so you eliminated the monitor and cables as a possible cause </font>
Actually that's not true, I haven't really tried the second card yet, I haven't had the time to go through it yet.<font face="Verdana, Arial, Helvetica" size="2">and you've tried 2 cards so it isn't a faulty card the problem either.</font>
LOL You don't know me very well do you?<font face="Verdana, Arial, Helvetica" size="2">Btw... do you have the possibility of trying the card on another system,just to see what happends,since the card is quite a bit more power hungry than the G400(it runs right at the limit of the agp spec).</font>
Rags
Man superfly,
Too bad you don't understand that Rags knows what he's doing, and has covered 3x the angles you can think of. Maybe the VisionTek just doesn't look as good.
Yeah... I guess those bionic eyes really cause you a lot of hassle eh Rags
That's what i'm trying to figure out too because i don't have the those problems at all,not a single one....
Anyways try out the second card when you get around to it and post your findings...thanksnote to self...
Primary system :
I may have found one your problems(screen shaking).
On my system i set the mouse refresh rate at 200 hz(i'm using a logitech mouse).
Because if i set at anything below 100 hz, i also get the screen shaking problem you mentioned when using the scroll bar.note to self...
Primary system :
