I'm running win2k as well,but if you use a logitech mouse there's a setting for mouse refresh rate in the mouse driver properties.
Even if you don't use a logitech,there's a handy little utility called ps2 rate that works with any mouse and allows you to do the same thing anyways.
The monitor i'm currently using is less than a year old,it's a sony CPD G400,and one of it's strong points happends to be how well it displays text,even if i'm using high resolutions.
