Galvin:
If you needed to turn off PnP to make Win2k work, you have more problems than we can go into. My advice:
Step 1: Backup.
Step 2: Turn PnP on, make sure all your BIOS settings are ok.
Step 3: Reinstall Win2k in ACPI mode.
Then see how things work out. If Win2k is already in ACPI mode but your bios is set to non-pnp you are totally screwed as things stand.
- Gurm
Listen up, you primitive screwheads! See this? This is my BOOMSTICK! Etc. etc.
Step 1: Backup.
- Gurm
