Originally posted by Rags:
Galvin,
No one said that setting PNP OS to on will fix the texture corruption.
*sigh*
Let me explain (warning: deductive reasoning is involved).
1. You are getting problems with texture corruption that others are not. I have not seen everyone say yah, I have all of those on my system as of yet. You are amongst the minority.
2. You cannot use (properly) a function in your BIOS under win2k in which it NEEDS to function the way you currently have it set up.
Because you are experiencing 1., you should be looking at getting your system properly set up to be sure it's not a driver problem, and since you SHOULD be looking at setting up your system properly, you should be looking at 2. very carefully. Gurm has told you how to take care of 2., but it looks like you won't listen (big surprise). So I have no doubt you will be experiencing 1. for some time until you do decide that there is a preference of order in setting up a computer system to run problem free (or as close to as possible).
Rags
Galvin,
*sigh*
Rags
I already said here that I turned PnP OS on, it didn't change any IRQ's I got lucky on that one.
